Transmission cooler lines
COLE SWEAT
After adding the gussets to the frame and dropping in a big block with a road race pan, I found out the ss transmission cooler lines
For the 400 trans will not fit. First they hit the oil pan kick outs and then they hit the gusset on the motor mount.
Is anything easy?
Has anyone ran -6 braided lines from the transmission to the cooler? If so, how did you route them?
Pictures are worth a thousand words
Inside frame, maybe?
Run as far as you can out side, then cut hole on neutral axis and fish lines through.
