big2bird
I finally got around to this project today. The cooler is 6" tallx 24" wide by 3/4" thick, and is an aluminum plate type. (Noonie turned me on to the manufacturer).
It runs from one side to the ther of the condenser frame, and with some simple aluminum tabs heliarced on, tek screws right on. It has 1/4" clearance from the hood when open, and has 3/8" barbed inlets and outlets on the driver's side. It just clears between the A/C condenser and the headlight actuators. (I had to loosen them to install).
All in all, a productive day. I hope this solves my o-heating on the hills in low gear. The cooler holds about 1 qt.
		 h:
h:
