js292 Well-known member Joined Mar 23, 2008 Messages 228 Location Canyon Lake, TX Apr 14, 2010 #1 Got my new throttle body in and the coolant port sits on the runner. Any have any suggestions?
js292 Well-known member Joined Mar 23, 2008 Messages 228 Location Canyon Lake, TX Apr 14, 2010 #2 I know it's not bolted up tight but there isn't enough room for the heater hose.
BBShark Garage Monkey Staff member Joined Mar 5, 2008 Messages 5,101 Location Right here Apr 14, 2010 #3 Cut it off and don't use it. The water port in my IAC plate is filled with epoxy.
SCCA VETTE Well-known member Joined Jun 11, 2008 Messages 206 Location Kokomo IN Apr 14, 2010 #4 BBShark said: Cut it off and don't use it. The water port in my IAC plate is filled with epoxy. Click to expand... I agree with BBShark! :drink:
mrvette Phantom of the Opera Joined Mar 24, 2008 Messages 15,194 Location NE Florida Apr 15, 2010 #5 SCCA VETTE said: BBShark said: Cut it off and don't use it. The water port in my IAC plate is filled with epoxy. Click to expand... I agree with BBShark! :drink: Click to expand... :clap::noworry::wink:
Twin_Turbo Der Maulwurf Joined Mar 5, 2008 Messages 7,575 Apr 15, 2010 #6 don't need it, I cut the entire water passage off, if you want it spiffy looking, TPIS sells a billet iac housing with the water passage deleted for around 40 bucks
JeffP1167 Well-known member Joined Dec 21, 2009 Messages 2,727 Location Yucaipa, CA. Apr 15, 2010 #7 notch it like a "V" then bend it forward to close the "V" and have it welded. After it's welded simply sand the new weld and slip the hose on.
js292 Well-known member Joined Mar 23, 2008 Messages 228 Location Canyon Lake, TX Apr 15, 2010 #8 thanks for the suggestions
js292 Well-known member Joined Mar 23, 2008 Messages 228 Location Canyon Lake, TX Apr 15, 2010 #9 I went the fancy route with the TPIS delete :waxer:
