Tool For Trailing Arm Bushings
Plate dimensions: 5'' X 2'' X 1/2''
Bolt Size: 7/16''-20; 3.75'' long
Flaring Tool: air chisel shank
Compress rubber until distance between the two plates is 2.25'' (you can cut two pieces of pipe to fit onto the bolts if you want). Flare the bushing using the air chisel shank and a hydraulic press.
Thanks, that will same me allot of money since I think I have everything I need laying around already.
