MYBAD79
Moderator
I'll have to pull the trailing arms and replace the spindles and install new wheel bearings, install JohnnyJoints and add a few welds to the stitches that the factory welded on these trailing arms.
I also want to upgrade the existing callippers to O-ring calippers.
Rack and pinion conversion with homemade support cradle for the rack (similar to the Flaming River cradle)
Upper strut rods for the rear suspension (partly done, need to add brackets to the trailing arms and drop the crossmember to weld to it)....
Spreader bar for the front suspension
OK... I should be back on the road by spring 2012 right ????
:bonkers:
h:
