Thinking about a shift light
JPhil
Huh?
Loveland, Colorado, USA
So I'm thinking about a shift light for my TKO600. I don't want a regular 3/4" diameter one mounted on the dash board like my drag racer buddies have. My idea is a subtle little LED light under the hood, in the windshield wiper tray. Doesn't need to be obnoxiously bright and I want it to only flash for a second or so, not stay on if I exceed that RPM.
I'm running the mechanical tachometer, but my MSD 6A box has an electric tach plug on it I can use.
In brief searching of the interweb I don't find anything that really satisfies me. Anybody here have any ideas or suggestions?
Hey John -
I have one of these,but currently I think not available-upgrading production run:
I added one of these to the little racecar:
No shift light, but it is a soft cut rev limiter with no-lift shift. Quick way through the gears. You can feel the engine run out of its legs at the set point, clutch in, shift, go. BTW; the British pound is way down so great value with USD!
When the hood is closed you don't see the gauges & shift light
