big2bird
I have, for the most part, always used Paragon Repo shafts in my rebuilds. The gears seem to mesh better, and the Mid America shaft has no chamfer on the oil pump end. (Aids in insertion). Now, while you can use a Mid America shaft, and either chamfer it with a grinder, or just struggle a little longer to get it in the engine.
So today, I am finishing assembly on a dizzy for a VM member, and since the car is going down the road, and I am out of Paragon shafts, I decide to use a Mid America shaft. WRONG.:tth:
Look at the following pictures, and see if you spot the problem. The Mid America shaft has the squared end, and is the top shaft as viewed..
Lars will pick up on this right away.
