T-top alarm switch HELP
ToddG
how exactly does it work? I had to disconnect mine because I broke it. I know one wire was ground and the other was connected to a plunger so when the t top was locked the pin extended and pushed the switch. That is the part I broke. the wires are just hanging in there now. Now when i lock the car and after about 5 minutes the alarm horn will go off. When i unlock it it turns off. I need a fix until i get a new switch. car runs fine.
thanks
ToddG
Tape up the blue wire so it can't go to ground , that should be a temp fix until you get the new switch.
