Sway Bar?
WhiteShadow89158
SoCal, CA
So i was browsing through the shops and i saw a rear sway bar. Does the 81 come with a swar bar? Mine doesnt have one and if so can i get a pic where it mounts?
depends, if you had FE7 it did. mounts to the frame there are threaded holes in the back
IT's all bolt on, 2 srtips with 2 bolts/nuts each for the trailing arm, the sway bar and those bushings with the mounts that thread into the frame. Holes in the frame and trailing arm are already there. If you have a stock sway bar it was different end links than aftermarket, aftermarket uses the same as the front style.
That's not an exhaust system, it's a rear end cooler w/ air ducting. The pump you see pumps the fluid through the oil cooler behind the carbon box, it's thermostatically switched.
Isn't that your exhaust vacuum? You patented it didn't you?:bump:
