Steering rack help
voodoovette
Crystal Lake Illinois
Hello,
I am looking for the best rack and pinion to use on a C3 with FRONT steer using C-5 front suspension. I need to identify a rack that is the correct length and gives me the quickest ratio. A factory type or aftermarket is fine, just need some information from someone who has converted over to front steer with updated suspension. I appreciate all info, thanks.:drink::nuts:
All depends on what you do with the a arms, how far they are apart determines what rack width you need.
I have a front steer rack, 16.5" appleton quick ratio but everything is hand fabricated on mine, no factory parts. Stock arm positions are very narrow, hence the 16.5" rack.
Thanks TT,
Yes, I am measuring about 16.5 inches and this seems very narrow. Anyone know the measurements of a C4 or 5 rack. I believe 16.5" is about as narrow you can get from most of the aftermarket racks. Mine is all fabricated, including the frame as well, so I do have options. Are you happy with the Appelton rack and do you have any pics to share or your setup? thanks.
