SPC adjustable control arms
vette427sbc
Jersey Shore
Finished putting my new SPC control arms on... Very nice pieces, no more shims, and SUPER easy to change camber/caster. Cant wait to get these dialed in after I get some tire data at the next track day.
They have chromemoly cross shafts, delrin bushings, aluminum adjustment sleeves and Howe "nascar" style tall ball joints. They also make it so I can run my brake ducts through the arm instead of around which made my tires rub them on tight turns
I have these A-Arms in my car from 5 years..... very good stuff!!!!!
You will enjoi !
By the way it is nice idea routing the brake ducts through the arm!!!!!!!
I guess I will copy you.....:clap:
I'll do a copy on that as well.
How do you dump the duct to the disk?
A close up pic would be great if you have one.
One thing that concerned me is that the 3 bolts that act as the pivot points are only grade 5 with no shoulder. What kind of loading do these bolts see? maybe something worth changing out to at least a shouldered bolt?
Just a piece of 3" exhaust tubing ovaled at one end
