TimAT
Addict, Cruise-In Bird-Run 1 Veteran
I'm kicking around ideas for Ol' Red. It scares me to think of that LS-7  crate motor getting broken, so I'm thinking about a heart transplant. I was thinking about building a 540, but the cost difference between that and a 496, I can't justify the 540. So looking at 496 rotating assemblies--
Both Scat and Eagle have the parts- crank, rods, pistons.
Anyone have any comments on the difference/durability of Scat or Eagle? Callies seems to have a really good crank, but they're also really proud of it. I'm assuming the same with their rods. Same with Childs & Albert.
I'm looking at 4340 forged cranks, 4340 H-Beam rods with ARP bolts. The cost between Scat and Eagle is not really a factor. I'll probably not run it hard enough to make the cost difference between the Scat/Eagle and Callies worthwhile.
Glenn found a block, and when I get this rolling I'll use ARP studs on the mains, and very likely AFR Heads.
