SBC iron intake mani..Qjet....
mrvette
Phantom of the Opera
NE Florida
Took motor home for a ride in 100f shade tree temps yesterday around noon....must have been 140 on the highway, city traffic stop and go, idle for long time with a/c on....
engine went to fuel perk soon as I got to the road leading into the house....
died, of course, would not restart....fuel pump sounded stupid, like it was outta gas....
waited a hour, went back, started right up....ok, heat soak from the heat riser, BTDT, but it has been decades...maybe 25 years...
SO, I pulled the intake this AM, and in filling the cross over after cleaning it up pretty good, I found a crack down in the belly of the casting, following a inside radius, fore and aft....found it because of water weeping outta it from the filler, I can't find the Plaster of Paris, so used unsanded tile grout instead....cement product, should dry hard and durable, I hope...P/P always lasts good....
NOW, I have a alternative of a Edel Performer mani, I blocked the crossover in it, also....
so WW U Do???
:twitch::skeptic::cussing:
so WW U Do???
:confused2:
Don't think i'd use the iron intake with the crack...it could get worse. I would replace it.
Is there a return line on the pump?
NOPE, this is a olde tyme system and just a little pump like I had 35? years ago in a dual tank Chebby van....with ign on and engine still, I can hear the pump rattle with fuel, and the sounds of it are fairly obvious with experience...
SO, the thought that the cast iron mani will have a further failure is what I was concerned about....
but was wondering if it was a common compaint....I just wish I had pulled that iron intake a couple years ago, and put that bit to BED...
I can't believe anyone that supid to put a unwashed intake on a fresh engine...makes me wonder if the carbon shit didn't affect the bearings, causing lo oil pressure, even though the lifter valley/cyl heads are clean as a whistle.....
I thinking of changing oil/filter and using 20W50 oil and a WIX filter...
if it don't come up, change that filter fitting ....
on the right track? or not??
:drink:
Wix are good.
What's up with the pressure?
Never goes above 40 psi, hot idle 600 rpm is less then 20, closer to 15, now that I see that intake all messed up, methinks there maybe some bearings issue, all that shit in the oil....
:crap:
