enkeivette
- Joined
- Mar 30, 2008
- Messages
- 990
- Reaction score
- 0
So I sanded off the first 6 layers with a DA, leaving only the original primer. Then I started to take off the primer with a rigid and a flexible sanding block. As SMYDA has said before the original SMC was not perfect and sanding reveals the low spots. So in trying to get rid of every last bit of primer, I've started to see fibers in a few places and there are still spots of primer in those places!
So where do I go from here? Do I need to get rid of every last bit of primer? Should I attack the spots individually (waving the body) or should I leave them alone? Should I go over the fender where I can see fibers with some filler? Or is it not a big deal?
