Red Rtv
DARROW 74
SAN CLEMENTE CALIF
How many of you have had good results using the rubber end gasquets on a intake manafold install? I haver never had a problem with rtv only being used instead. what were your results?
Never used the end gaskets. Always used the RTV...advice given to me by a very experienced engine builder.
I use RTV. I wipe down where I want the RTV to be with alcohol so it'll stick. I use black but red, white, clear, all do the same thing. red is usually hi-temp.
When I pulled the intake recently to change the cam I noticed that I had the rubber end seals, I didn't even remember installing them, anyway, I left them there but applied a liberal amount of RTV to them upon reassembly. No leaks before or after.
Usually I just use RTV though.:goodevil:
Hi
Used 5 8 years ago the end gaskets together with red high temp RTV and no leaks. Last spring I installed the tripower setup, again used the rubber seals with red RTV top and bottom of them and is still OK.
I trial fit the intake first with only the end seals to assure that they are not squesed too much preventing the intake from siting down enough.
Using only RTV on such a high gap ?? I think definately OK if the block is decked.
Günther
Let's see ... this isn't easy to explain but here's what I did: first I installed the intake dry with thick shims instead of the gaskets. I tried to line up the boltholes first. I determined that I need a .120" thick intake gasket to line up the holes in the intake with the threaded holes in the heads.
I measured the gap at the front and rear of the intake and it was about as big as the uncompressed rubber gasket. It would not have sealed with the rubber strips alone.
I used RTV and let it cure for about 3 hours, then installed the intake with it's gaskets but did not tighten the bolts yet, I waited over night and then torqued the bolts.... no leaks, it's been over a year, so far so good...
hope this makes sense:
green: intake
yellow: rubber strip thickness
light blue: intake gasket thickness
