Twin_Turbo
Der Maulwurf
- Joined
- Mar 5, 2008
- Messages
- 7,575
- Reaction score
- 6
Here's how I modified a pair of stock trailing arms for coil over shocks.
The biggest issue I noticed was that the shock mount would introduce a torsional load on the trailing arm, something which the semi free hing bolt of the leaf spring does not do. I needed to find a way to make the arm more torsional stable without having to cut up the entire arm. There was no need for offset arms and such. Xander (V-Twin) came up with the idea of cutting holes and welding in tubes. That should make it considerably stiffer without adding a lot of weight.
This is the complete arm, ready to be installed.
The length of the mounting bracket depends on what length shock you are using. If you are using an 11" collapsed length shock, they need to be longer than this.
