mlpettus
Member
- Joined
- Jul 6, 2008
- Messages
- 16
Well I am just about finished with the front and rear suspension modifications and I am not real happy with rear suspension. I raised the rear diff crossmember by removing the rubber bushings and welding in steel plates. I also modified the front diff mount to keep the rubber bushing. Problem is when I set the car down on the wheels and set ride height my halfshafts are about 1/2" higher at the wheel than the diff. Not ideal for the toe curve.
Has anyone else had this problem and have to raise the diff more than 3/4"??
Front Diff Bracket Modify
Crossmember modify
Rear Assembly
Ride Height
Crossmember modify
Rear Assembly
Ride Height
