vette427sbc
I have a leak at the filler neck of my radiator. Any suggestions on how I should go about fixing this? Torch and solder (I only have a MAP gas torch. No oxy/acetylene)? Epoxy? JB weld
You might be able to drive the car to a rad shop and have the braze it right on the car. It's worth a shot, but I'm not positive they can do that.
Mapp is plenty for the neck. Brass, I assume.
Use the older less tinny solder, Has much lower temp.
I called another shop and they told me I had to have the rad out of the car. :suicide: Not trying to do that now
No offence but if you're not real handy with a torch and solder, take it out of the car and get it done by the shop.
There's very little temperature difference in successfully applying solder to your joint and melting all the solder on the whole damn radiator! You fix your leak but introduce 20 more :waxer:
It's definitely a knack, is all I'm saying :idea:
Me neither :amazed:No offence but if you're not real handy with a torch and solder, take it out of the car and get it done by the shop.
YUP, and don't ask how I know that....:shocking:prrtt:
