Bee Jay
I asked this over on the other forum also, but I think all the engineers are over here. Twin Turbo, what do you think?
I'm in the middle of installing my aluminum batwing diff cover, crossmember. There is a frame crossmember just behind where I will be mounting the batwing brackets. This crossmember seems to do nothing. Nothing is bolted to it since I don't carry a spare anymore, and I think it may not be needed anymore since I am running a welded in four point roll bar. The roll bar really made a significant difference, a difference I could easily feel, in chassis stiffness. Just behind this crossmember is a bolt in steel crossmember that is used to support the gas tank. At the end of the frame, I removed the heavy battering ram crossmember and replaced with an aluminum angle bar. If this crossmember is not doing anything but adding weight, I'd like to cut it out. What do you experts think?
Bee Jay
You can see where the four point roll bar is welded in in this picture:
You can see the cross member in question in this picture:
You can also see the bolt in cross member for mounting the gas tank.
Here is the Autopower four point roll bar from topside:
Bee Jay
