- Joined
- Mar 30, 2008
- Messages
- 3,077
- Reaction score
- 38
Going to be welding up a new exhaust system in the near future, but I'd like this system to be a bit quieter than the present one. To be honest, the exhaust note/noise out the back ain't bad, as it's not that loud. It's the underbody section that rings like a tinny bell with each exhaust pulse out of the header collectors. I'm trying to understand the mechanism. Is it a pressure pulse that's hitting the pipe walls, and making them ring like a bell (sort of like detonation excites the cylinder walls and makes that characteristic knock noise)? I'll be taking out the present 2.5 inch tubing and running some 3 inch tubes. These bigger tubes should theoretically resonate at a lower frequency, and along with the slightly greater mass (a three inch tube of similar wall thickness would weigh more), and the greater interior volume that would reduce the instantaneous pressure peaks, I'm thinking this might quiet down some of this ringing. I'm also thinking of trying to maximize the common plenum volume (both banks feed into a large single pipe) in the system to assure that both mufflers see the same pressure. I've got that on the present system, and the exhaust note seems to have a slightly more subdued note to it, in that there aren't the loud single pulses coming out the pipes.
Okay, back to my original question: What is the mechanism that makes the underbody pipes so noisy?
thanks,
Mike
thanks,
Mike
