Eastltd
Member
Please help me solve my off idle stumble.
I have a 73 454 with the Edelbrock performer heads, intake and 750 carb (1411). The car has an MSD 8572 Pro-Billet distributor set with 12 degrees of initial timing and the centrifugal advance set at 21 degrees. (one light silver spring, one light blue spring and the blue advance stop)
With this set-up the centriugal advance curve starts at 1200 RPM and is fully advanced at 2400 RPM.
I have the carb now set at the base setting (.110" main jet & .075" X .047" rod).
If I let the clutch out at idle 800 RPM I get a stumble for a few seconds.
Should I be chasing carburation or timing?
Help from any of you fellows would be greatly appreciated.
Thanks in advance.
BTW, I measure 14" of vacuum at idle.
Ian
Thanks in advance.
Ian
