Pretty convincing video of Beehive valve springs
Your right that is pretty convincing.
I plan on upgrading to comp cam valve springs when i get my LT4 Cam.
Met
Yeah, but that was the point. Wasn't it. There's arguments on both sides.
I think the point was to show that they have better hi performance valve spring.... Right?
Met
yep. I'm just sayin' it was taken from a position that beehive is better and the video proved a pre determined position.
All I am saying is consider the source. There are educated people on both sides of the issue which will make the point one way or another.
Not saying they are bad at all. I remember reading there were some problems with some made by Comp or Crane for example.
As I always say, how much of a difference will it make given the overall combination.
Their advantage is that they have a progressive rate to help better control the valve. Light on the low end, heavy at the steep end. Exactly what is needed.
Met
Comp had some "problems" early in the production.:quote:
How do you know that the traditional spring was even close to being appropriate for the application?
I bet you could make the beehive spring look pretty bad in that test if that was what you were trying to do.
Mr. Vizard has totally swallowed the beehive story.
There are 3 reasons to NOT get a beehive spring
1.) no damper spring to save your motor in case a spring breaks
2.) Cost
3.) limited availability of spring pressures for the really aggressive roller cams
if you are running hydraulic anything they are probably the way to go.
Reasons to get them
1.) Lower spring pressures to control higher RPMs
2.) OE usage is bringing costs down and reliability up. Kind of like OE introduction of roller cams
3.) Lighter valvetrain weight
4.) More lift from same installation heights
Hyd Cams have been running forever just fine without them for years.
