68RAT
Member
Okay I got a re-occurring problem. First some history and facts: I installed a new (old system new parts) Power Steering system in the 68 last year. I had some problems then and adjusted the power steering control valve until it was balanced in the middle quite well. It seemed to operate okay but not as easy as I thought it would. I decided to live with it, as it was an improvement on the old non power steering.
I also got an alignment last year and my settings were as follows:
FRONT:
Caster Left: 2.4* Right: 2.4*
Camber Left: -0.1* Right: 0.1*
Toe: Left: 1/16" Right: 1/16" Total: 3/32"
REAR:
Camber Left: 0.1* Right: 0.1*
Toe: Left: 0.0" Right: 0.0" Total: 0.0"
Thrust Angle: 0.0*
The previous owner(s) installed on the front suspension new bushings, ball joints, tie-rods, idler arm, spindles, bearings, larger diameter sway bar, springs. (550lb). The rear suspension has a new VB&P fibreglass mono spring and added a sway bar.
I'm running 255/60/15 BF Goodrich T/A Radials with 26 lbs of air. I was noticing some wondering so adjusted the power steering control valve again and it is centred again. It was off a centre again…. Should it need centring again?
The re-occurring problem:
I find on some corners (usually hard ones when I'm pushing it a little) the power steering will pulse with effort to a real easy turn then back to what it was before. This of course causes the car to turn sharper for a 1/4 second as the steering wheel will turn sharper because I am really cranking it in the corner. Besides scaring the $hit out of me it is dangerous. This is very more pronounced if there was a bump/crack or deep groove in the road. It will also jump from side to side when there are ruts in the road made by the HEAVY loaded trucks.
TODAY the wife and I were coming home from a car show and I pulled out to pass a slower car on a straight away and during the pass I crossed a cement bridge with a large 'crack' in the pavement where the cement and pavement met each other. When the front tires hit this crack the car's steering literally bounced the car sideways to the right about a foot or more. I was already past the car I was passing so I was nowhere near that car but it sure scared the $hit out of me. (and worse the Wife TOO!!!)
The Wife refuses to ride with me now until I get this FIXED. Do I need another alignment? Do I need to replace my control valve as I have read that sometimes that even a new one may not operate properly right out of the box. Would new narrower tires on the front help? More/less air pressure?
I'm reaching for straws here guys. I need help. I just remembered that my steering is a little loose as I have a little play in the steering wheel. It's not much. I can move the wheel from 12 o'clock both ways about a ½ hour each way. I've driven vehicles with WAY worse than that and NOT had any kind of similar problems.
Sorry this is a little long but I am trying to give all the information I can to try to get to the bottom of this problem. I LOVE to and want to do LOTS more driving but this is starting to get scary. We want to go on a 2000 mile road trip this September but if this isn't fixed we won't be taking the vette.
Thanx for any all suggestions.
68RAT
FRONT:
REAR:
Thrust Angle: 0.0*
68RAT
