Posi 10 bolt pickups.....
mrvette
Phantom of the Opera
NE Florida
Yeh, it's about the silverado again....'96, 1500 ext cab, 5.7 Vortec....
auto trans, but dunno, suspect 4L60e.....
ten bolt open rear, need posi.....
last time I swapped a posi carrier into a ten bolt, it blew up....put in a 12 bolt....
same thing on a Mopar 3/4 ton van.... with a smaller rear, put in a 9.25 posi rear, break THAT!!!!
SO, how common is posi on this vehicle?? much less how common is a 12+ bolt rear for a swap?? any clues about gear ratios??:beer:
I would think that there are a few out there, my 01 1500 ext cab had a 3.73 posi in it
Trans is a 4L60e. The rear might be a little tough to find. Do some research- GM did a few funky things with axles- there might be 10 bolts around the cover, but it could be an oddball size.
