Percy's adjust a jet
kwplot34
Heart Attack
Liberty,Mo
is anybody using one of these,i installed one today and i am having a problem,with the needle turned all the way down which would be less than a 60 jet size i am getting way to much fuel,the venturies are flowing like a river :mad:,the float level is a little low so no problem there,and Percys is closed today :cry:.
Can anybody HELPPPPPPPPPPPPPPP
never mind i figured it out :noob:
OK, so what was it?? :waxer:
Well after i got through battling the accel pump it would get as hard as a rock after a couple of pumps and no fuel coming out of the squirters,the gasket that was sent for the bowl to adjust -a-plate, covered up the accel pump hole.
So i did not bother checking the gasket that goes between the metering block and adjust-a-jet :crap: when you install this plate you take out the jets,no longer needed,well the gasket has 2 holes for the jets,which did not line up either :suicide: so what jet size would that be 100k maybe.
I wound up using my old gasket for the bowl side,and had to be very careful to make sure the gasket for the jets stayed in place.
