Oil out of sidepipe.
mdbelanger
Almost broke my 3rd.....member
New Hampshire
Half a mile from home I stompped on her and ball of blue smoke beside me.
Drivers sidepipe soaked inside with oil.
y1p8OyqRMfs2R-NObCBB2-UdsfyhpvzSwRk_btcJhjT2LUluDVwf5xnkzSEYofOZdon
Pulled plugs on drivers side. These have over 4000 miles on them. #3 heavy in oil.
y1pegB98TIkz2hCR8GFQgHB3ymtf9r4icvLEE81d-nPrlGGYaa2-LMUgPOwreRv_N6K
This motor is a 385 Fast Burn. On the road in October of 2007, have put 17,000 miles on her.
Looken for thoughts on how deep I am going to end-up on diggen.
Michael.
Does it smoke blue after startup??? (seals)
If you run on the highway and coast and then stomp it does it smoke blue then?? (rings)
Could also be an intake gasket
Did a compression test a few hours ago. # 1,5,7,2,4,6,8 all reading at 175 to 182 psi. #3 25 psi made my balls climb up to the back of my throat.
Pulled the head now setting up to pull the motor.
y1pwxT6M_dZTugAi8tkJvzQ2x45jhCWLcJbQbh1_uSgSdl0F1nxUU-RX0YbBzDdqqtp
10 o'clock is missing an edge of piston.
y1pF1CGNd4KP57trEcBxtn9A_nySojKK0ijWfqRSPwgoMmXZzgK5_j7XE-HbXqCgjWQ
y1pm32W1XjDe4bDKbiJ4i_84UZUCjJjViO7mqacasboymczpfpP-yCnUNNCy3_CCgCy
y1pL3mTC8dNyFqJ6dRimhipVddYO8ZLPjPJSHQ-JmLwqVyyBvyGLHiJP1r5M4mFdwR9
Need some feed-back folks.
Think this head is salvageable?
Guess while I am in her this deep some porting and polishing will be done.
Getting ready to order new pistons and rings, any sugestions on what could improve this 385 Fast Burn?
Michael.
Please move to "engine mods" due to I see a few comming?
Ring land breaking off, that's detonation damage.
alu fast burn heads? those can easily be repaired by a good shop, no problem.
if it's detonation, why only one cylinder ?
looks like the piton next to it (#5) is damaged too, or is it the picture ??
Oh man, what a shame, I bought a set of aluminum heads with that kind of damage on them, head shop fixed them right up, not an issue not even broken....wish I could say the same for your piston there, you could always try some JBWeld....:stirpot:
then again, maybe NOT....sorry to see that man....
:crutches:
One cylinder will fail first won't it? Honestly, that is typical detonation damage. I doubt it's too small a top ring gap in case these are hypers. You'd see marks on the cylinder wall for sure. This kind of failure is the result of an overheated piston crown.
Ok Folks back home for awhile.
Pulled the other head awhile ago and cleaned em up a bit to get some better pics.
I seam to rember a Piston Co. that showed all sorts or piston damage. I can't find the site anymore. I recall that what I'll call "Pin prick marks" is a sign of Detonation.
These pics are in the order of 2, 4, 6, 8, 1, 3, 5, 7.
y1pmY2BnsgzsdWsZibKKDjoR8ITSuGeNXjjn31E4cUusDkc7myO97NdCVA3CQd7LpFd
y1p-fj0MwwWQbReN5RSkFtVTyykfVm7Yb8RV3WZfFgsMJbuUfdcABbeaYTENhrEe1lY
y1pmJhL-1uI-ZBKORfFqoD8Xgx6_3-ohkYDp2muNUO3ESRfVx-o_Fe-EUhCC4zFNQBR
y1pbFA6DTOnhke6n8UmFI5k32aouJnPnxObizdjEuUct3QanUN1xZte1YpBIXpW5mqW
y1pxgHGCZn6Gm1kiRXUZi0C6pQpmfllZhliJuSkCzJQri80hRGjIx3XyiCJvyfJ6ASd
y1pmbyDembW0aQnxtWFF0lgf6ZTvzZOqwogZy04F16MO8CceZz1zRPAWPinim2INpZS
y1pu8NLWdTG65fXV_Pv_K_rjXwyyoSOjkJnn33DETVGfa5A3cIDrQz_-OTynyILDW4N
y1p5fM_NrPaQFjHM9KUkxZI9m2GlycVUQHD3_N2wa4tIBSyljRa4EEp6Jk8GtE-SFmC
Now to pull the block.
Michael.
Its the picture I'll get more when it stops raining.
Your not very far from me, Hang onto your ass when you get a new piston from GM and if you change the insert have the rod checked for size as we just rebuilt a crate engine and the rods were .2.2240 and we machined them to 2.2252 to get our required clearance.
The spec on that rod is 2.2247 to 2.2252
May want to spray some break clean in the intake and exhaust ports to make sure there is no seat damage.
Good luck with your build Carl
Now its time to start thinken of what to order.
This Vette is for the street and hauling Deer.
The specs on the GM 385 Fast Burn:
Fast Burn 385 Tech Specs Block Part Number:
10105123
Block Type:
Cast iron with 4-bolt main caps
Bore x stroke (in):
4.00 x 3.48
Camshaft duration (@.050 in):
208 degree intake / 221 degree exhaust
Camshaft lift (in):
.474 intake / .510 exhaust
Camshaft Part Number:
10185071
Camshaft type:
Hydraulic roller
Compression ratio:
9.6:1
Connecting Rod Part Number:
10108688
Connecting rods Type:
Powdered metal steel
Crankshaft Part Number:
12556307
Crankshaft Type:
Forged steel
Cylinder head Part Number:
12464298
Cylinder head Type:
Fast Burn aluminum; 62cc chambers
Displacement (cu in):
350
Engine Name:
Fast Burn 385:
Engine type:
Chevy small-block V-8
Ignition timing:
32 degree total @ 4000 rpm with vacuum advance disconnected
Maximum rpm:
5800
NOTE:
Distributor with melonized steel gear MUST be used with long blocks and partial engines with steel camshafts, or engine damage will occur.
Piston Part Number:
10159436
Pistons Type:
Hypereutectic aluminum
Recommended fuel:
92 octane
Rocker arm ratio:
1.5:1
Rocker arms Part Number:
10089648
Rocker arms Type:
stamped steel
Valve size (in):
2.00 intake / 1.55 exhaust
Gm Dyno Chart:
y1pqs7POdbWESsAJlX074SEQE6QoyWBXX-V8I2lHy-HxE0xz1AiAimtS9-6I8av5KMd
I would like to get a tad bit more out of this motor if possible.
Heads specs say I can mill .060 of an inch off. I believe .030 will be enough, "so that I can do this again".
Head gasket calls for: Stainless fire rings, .051" compressed.
As for new pistons, open to all sugestons and why.
All help is appreciated.
Get a thinner gasket, it will be more detonation resistant. .051 _ piston down hole gives you 0 quench effect.
Flat top hypers will be fine.
