I'm hoping some of these problems have been corrected on the newer Champion, 3 row/core, 4 row/core radiators. In my case it's for a 75'
The lower radiator hose connection on the passenger side, points straight instead of in the up direction as per OEM. From what I've read this problem has been corrected on recent purchases.
On automatic trans, you can't use the connections on the Champion rad's which is why they offer a free transmission cooler with purchase.
The petcock is on the driver’s side and interfered with the radiator support whereas oem is on the passenger side.
The 4 core/row is too wide for the small block motor, which to me doesn't really make sense, but I have read this, without any photo proof.
Below is the online photo, which does show the lower rad hose in the correct position but the petcock is on the wrong side. Also I do see the auto transmission in/out lines but they seem to be capped and not threaded.
I don't know if the photo is what is being shipped or just a standard photo.
