new member
jim hudspeth
New member
Hi everybody,
I have a growl in my 2006 automatic vert that is coming from the rear end.
Swerving left and right does not change the growl.
When cold growl is very low 10 miles later its at its highest level
Growl increases with speed until approximately 50 mph and then is constant even if you increase speed.
Stethoscope indicates same all over center section of rear end.
68141 miles on speedometer.
Car driven normally, never on a track.
Any help or ideas would be appreciated.
Welcome to the motley crew.....
Sorry to hear of the troubles there, but from what you say, it's the diffy...look for leaks and check fluid levels if you can....not specifically familiar with your car, but it should not be driven much until you fix it, the destruction CAN be terminal to the carrier, and that = bux..... while there is a chance you can escape with a bearing/seal now....
:clobbered:
