Maymyvetteliveforever
When I first installed a GE 15086 in wall timer as per instructions and turned the power back on the 60 watt bulb I have hooked up flashed like a strobe light. It flashed on and off about 3 times per second when on timer mode.
I then rewired it as per the instructions I found online while doing a search and now it sort of works. The problem I have now is the 60 watt incandescent bulb turns on for a split second then turns off. Or it will not turn on at all, or it will turn on fine and stay on. It's almost as if there isn't enough power to get it going. It's rated for 40w to 500w and is cfl ready. Any thoughts? It would appear I'm not the only one with this problem based on online help forums but I haven't been able to find a solution yet. It's almost as if I don't have a solid ground even though the switch as well as wire going to the light is grounded to the box.
The power comes into the box, white it marretted together and black is wired to the switch then continues to the light.
