New Guy
mikey383
New member
Drumheller,Alberta,Canada
Hello, my name is Mike and I own a few vehicles,2 trucks,2 cars. My rare collector which I bought in 1978 is a 1970 Olds 442 W-30,(sweet). My current project is a 1982 Corvette crossfire, here is a list of mods I've done to date,Hooker comp. ceramic coated headers,Flo-Master Super44'S,Flo-Master True"X" pipe,Stainless turn down tips,Headers back is 2.5" aluminized pipe. K&N air filters,Accel performance 7 pin ignition module,Hyper-tech 50,000 volt ign. coil,cap and rotor,8mm plug wires,Hyper-tech thermo-Master computer chip and matching 180 degree thermostat,Edelbrock 255ltr.(67gph.) fuel pump,I took apart the rear throttle body to reset the fuel pressure regulator to 15 psi.(on a gauge),Edelbrock polished aluminum water pump(30% more flow),Pro-form chrome timing cover and tab,Flex-A-Lite 17" stainless and blue fan with a 2" spacer,Comp.Cams K12-364-4 cam kit,includes int.477/exh.472 lift and int.208/exh.217 duration @.050 cam,teflon seals,locks,retainers,double row timing chain and gears,and the new "Beehive" style valve springs. I also bought Comp. Cams Magnum push-rods and Comp.Cams Magnum roller tip rockers-1.6 ratio. Have plans to upgrade the trans. and suspension in the not to distant future,so I hope this gives everybody an idea of what I'm up to, nice to be here,talk at ya later Mikey383. P.S. I've also ordered the Pertronix Second Strike CD ignition box and a Mellings hi-volume oil pump.
Welcome to the motley crew of the Flying Dutchmen......
I too have been the A body route, had a '70 Lemans/GTO 455 I stuck DPFI on it....convertible, GREAT tow car.....
:bump:
