gbak
- Joined
- Mar 24, 2008
- Messages
- 89
Well, after my tuning of the carb and ignition this winter winter, I decided to check the result.
I also tested the car last summer and the result was quite ok, 440 hp at 5700 rpm.
(Drivetrain losses was calculated to 25%)
According to Desktop Dyno , the CS XR280 cam should give its max power at 6000-6100 rpm, upon that I also have installed the cam 4 degrees retarded, (to prevent engine ping and get a little more hp at the top rpm) so the top hp should be at 6200-6300 rpm.
What have been done since last pull is a swap from a Holley 650 dp to a HP750 with quite larger jets. (I'm right on spot when checking air/fuel ratio with a narrow lambda)
Here is the result:
Got a difference of 40 hp between the two pulls ???
And I also think the losses in drivetrain is calculated to 10% this time ????
What is your comment on this graphs?
This is a pull at third gear, HP on crank:
Same graph but HP on rear wheel:
Pull on 1st gear: (second gear went in at 4800 rpm)
The pull:
[ame]http://s236.photobucket.com/albums/ff28/gbak/Corvette%20-71/?action=view¤t=CIMG2127.flv[/ame]
Here is the result:
The pull:
