- Joined
- Mar 30, 2008
- Messages
- 3,077
- Reaction score
- 38
Found some of the problem
Managed to hook up a pressure gauge to the fuel line, and powered things up. Got 1 1/4 psi. That might explain why the engine doesn't like to run. The gauge is the one I bought to do some exhaust backpressure tests with, so hopefully there's not a problem using it for both raw and burnt fuel pressure tests.
I decided to pull the possibly defective LT1 fuel pump and swap the original '84 pump back in temporarily to see if I could get the engine to run. Once I got everything apart I noticed the pump outlet hose was ripped and spongy. It tore even more when I handled it.
I think I'll replace the torn hose and retry the pump to see if the leak was the problem, or if the pump has taken a powder. From the appearance of things it looks like the ethanol and water has taken a slight toll on things.
