What are you going to do with it?
For a GRAND?? you stole that one, :smash:![]()
I crawled under car today and found this.
On this 5 speed it has sight notches on bottom of flywheel where you can see it.
I took a screw driver and the flywheel can be moved forward and back by about a 1/4 inch.
obviously that is a problem but could the crankshaft have broke and that is allowing it to happen?
Unplugging one plug at a time make no difference.
Idle oil pressure stay between first mark and 60 psi and climbs as rpms do
harmonic balancer does NOT wobble nor does the serpentine belt
under the car it sound like the noise is more around the transmission
constant oil drip from clutch housing
prior owner said clutch was done about 5 months ago
If the crank was broken enough to move the flywheel back and forth 1/4 inch with a screw driver, the engine would self destruct in seconds.
Maybe when the clutch was "done" 5 months ago, they forgot to tighten the bolts!
Try moving the crank in and out from the front of the engine. If it moves the problem is most likely is the thrust bearing...
Flywheel loose on crank, gotta be.....:nuts:
Well I got a pry bar from a friend and yes the front crankshaft hub can be pulled out the equivalent of what the flywheel is moving.
What needs to be done now?
