Imo Apita
- Joined
- Feb 28, 2009
- Messages
- 244
Didn't want to post in "projects" since it's only a motor and not a full resto.
Besides I feel like a fish out of water there because of all the impressive work being done.
Mods, feel free to move this if you need to.
This thread is meant as a progress report. It will be mainly random thoughts plus pictures. Feel free to comment.
Here we go:
My car is a stock '79 with the L48 engine which I bought as somebodies never-finished-project, hadn't run in two years. That should have been a flag.
4 new tires and it became my daily driver. I think it already had one cylinder going bad, but I think I killed it with an oil change with full synthetic. In about 6 months it ran on only 5 cylinders and has been that way for the last year. Cam gone bad.
I managed to score a free piss poor running engine out of a '66 'vette.
Discovered that it was a '72 2-bolt 010 block with '65 heads.
Decided it would be the base for my 383 block.
Here's one of the first threads that you guys helped me with.
Wifey got laid off so the whole project was delayed.
http://www.vettemod.com/forum/showthread.php?t=4113
Picked up two weeks ago.:yahoo:
In the mean time the transmission is slipping and won't go into gear when it's hot. A TH350 rebuild seems to be not that much cheaper then a 700R4
Goal:
300 RWHP with a 700R4 so around 400-425 HP at the crank.
Goal is more tire shredding torque then max all out HP. Street scorcher more than flat out top speed. Stump puller, whatever you want to call it.
Overall purpose is to make small children and old ladies cry in fear.
I would like it to look as good as this (thanks to LarryWalk)
Found a machine shop locally and had the block done:
$700 for all the work.
Ordered the rotating assembly today $795 + $65 shipping so $860
Aluminum heads around $850 so I hope I can get it all running for $3000 total.
Never mind the fact that I can have a 383 stroker built for $3600.
Plus another $1000 for the 700R4 plus another $1000 to have it put in.
Total bill will be around $5500.
Purchase price of the car was 4K in June '08 before the economy took a dive,so total I'll be in it for 10K and that is without interior or paint. After interior and paint I'm guessing 12-14K.
Tell you one thing, it's not a good idea to start adding everything up.:twitch:
Anyway so far I have:
Bought the rotating assembly from Skip White Performance out of Kingsport Tennessee.
http://www.skipwhiteperformance.com/detail.aspx?Item=383-ROT
Will receive it in 4-8 days since they need to balance it on order.
These are the heads I plan on buying unless I find a better deal:
200 or 210cc aluminum Procomp
2.02 intake 1.6 exhaust valve
Some pictures from the disassembly:
Scratchy, scratchy:
Ready to hone at the machine shop:
I'll post some pictures of my shed and parts later.
Here we go:
Goal:
- Morel solid roller lifters
- Crane 1.5 full roller rockers
- 3/8 valve train stud girdle
- Main cap stud girdle
- Lunati rev kit
- +.030 rotating assembly w/ Scat 9000 cast crank, Probe forged flat top pistons
Scratchy, scratchy:
