SuperBuickGuy
I've done the google search, and looked through several forums for answers. The net result is everyone says "problem" but no one has come back after their "solution" and said "it works"
The problem. My tach isn't accurate. It reads 1500-1700 at idle (more like 900), and once you touch the throttle it reads 3500 at no point does it show actual rpm.
I put a 6AL on the car - the problem existed before the 6AL - however, the 6AL only made the condition worse. It doesn't matter where you hook up your tach - either at the distributor or on the side of the box. Granted, they have different issues. On the distributor it reads 0 at idle, 500 rpm anywhere about that. With the box, it has the same problem as it had before. MSD says do not use the filter. So I tried it anyway. I put the filter in line in from both connection points. On the box - it didn't change anything nor did it on the distributor.
I'll call MSD today and ask their solution.... then post it up here. (I think it's an 8920 tach adapter, but we'll see).
