1Michel
Hey I have not worked on the car for a while but this week end I finally found a few days to play in the garage.
So here what I've been up to.
First the car has been dissasembled for a while, I gussetted the frame and put the body back on the frame for test fit and also to aling the steering box to the steering column. I'll will install a Jeep box so the frame will be notched so the box can aling and a joint will be used instead of a rag joint.
I'm following Norval's install for the Jeep box, he's documented this a lot but I'll post pics as I'm going.
Today I installed the steering column then took the carpets and window tray out from the rear of the seats area. I also took the chrome trim on the top between the Ttops and found out my cage is pretty nice. Just a bit of surface rust. Also the windshield posts are solid and rust free.
One area that's bothering me a bit is the lower driver side winshield.
Theres a bit of rust there and . Also between the front of the bird cage and the cowl theres a separation due to rust and I'm afraid it will leak. I think I'll have to remove the windshield and make this area waterproof.
I'll try to load up some pics.
