The response I got from the VA tech.
Go through the calibrations procedure on page 11 of the link below and see if anything changes. If the system did work for several years then quit, I would guess it would be something in the ECU. You may want to remove the ECU and do a visual inspection – look inside the ECU case and look for any corrosion to the board. If it all looks good, I would recommend sending the ECU to us to test.
http://www.vintageair.com/INSTRUCTIONS/68-76 Corvette/903177 REV A 12.09.09.pdf
