Maymyvetteliveforever
Over the years I've done a lot of damage by raising the front of the car from the front crossmember and now need to repair it since the body is off. I was thinking of cutting out a section of 8"X14" and tig welding a new section in.
Questions;
Would you tig weld in one complete section or two since it's on a sort of bend?
What metal should I order, in other words, do I ask for cold rolled......what is the proper name?
What rod would you use?
Anyone know the thickness as I can only assume it's around 12 gauge?
I found someone that did the same type of repair but did it in sections, is this the better way?
Questions;
