Ohm out the wires to ground.
I did. I plugged into the relay socket and had continuity from the socket to ground. Are you talking about something else?
Disconnect the fan wiring at the fans. If the fuse pops the wiring to the fans after the relay had shorted to the chassis somewhere. If the fuse stays good, the fans are drawing more current than the fuse rating.
Same logic applies. Pull the relay. If the fuse still blows, the power feed to the relay coil is shorted to ground.
I pulled the relays. Both, and the fuse still blew. PLUS disconnected both fans. Still blew.
NopeSame logic applies. Pull the relay. If the fuse still blows, the power feed to the relay coil is shorted to ground.
Someone else is hanging on the line there, do you have a aftermarket stereo?? IF so, check around there first....
1/2 them installers are nutz....
:bonkers:
Just for you, Jsup..I checked my '91 shop manual. The gauges fuse, which powers the fan relay coil, also feeds many other circuits. A/C solenoid, stop lamps, daytime running lamps, both primary and secondary fans, 1-4 up-shift relay, alternator, air control valve, air divert valve, egr solenoid, and finally the canister purge solenoid. Welcome to my world. There is a pinched wire somewhere.
There's a good start. Just unplug all those items, or as many as you can, and turn it on. If it still pops, it's a wire.
Start plugging things back in till it pops. Then it's that coil.
Rather than keep banging fuses, why not get a 1156-7 bulb and wire it across the fuse terminal, the bulb will of course light, as the shorted wire will ground it.....then you go around unplugging loads/moving wires and watch the light....when you don't see the light, that's it....
I haven seen any light in a long time....:rofl:
Thanks Gene, will do good idea.
OK, now keep in mind that SOME drains for X amount of current draw will make the light glow to a varrying amount...but a dead short will make it really bright....so when pulling connections on loads...expect maybe a slight decrease in brill off the bulb....since all this is a unknown I"m trying to describe a phenomena ....not a very scientific thingy....sorry, best I can do with words....
:hissyfit::crutches:
