is there any glue that can repair broken abs plastic?
JeffP1167
Yucaipa, CA.
I broke a tab or two of my console frame and was wondering what I can use to fix the pieces that broke off.
ABS can be repaired with Weld-on solvent or even CA (superglue). For a good structural joint I would use Weld-on. ABS is easy to repair but a lot of stuff in interiors is PP (polypropylene), you can't bond to that at all.
AHH...so it was PP in the door panels of my '87, got nothing to stick to it....:cussing:
I'm wondering if a plastic welding shop can fix it. If not a few sticks a dynamite will cure all this cars problems and give it a new home on the moon! :goodevil:
:hissyfit::bump::bump: hummm....sounds familiar....:twitch:
