Worship79
I installed new H4 clear glass headlights this weekend. Not with relays, but with the stock wiring. When I turn on the low beams all is fine, nice and bright. But when I turn on the hi beams for a little while all seems well (wow! I can actually see where I'm going now), but then all four lights blink a few times and then turn off.
Video: [ame]http://www.youtube.com/watch?v=p7itiIHa3oM[/ame]
The voltmetre on the dash stays at a steady 14 volts, the hibeam indicator blinks with the lights and then goes out too.
What I noticed was that the lowbeams had already been replaced by H4 lamps and bulbs. But the hibeams were still the stock sealed beam type. However on the driver side there was a 2-pin type lamp and on the driver side a 3-pin type lamp, but with a 2-pin connector attached. Bubba?
For the 3-wire H4 hibeams to work I connected the third wire to the black ground wire (a test with the plus wire gave some funky sparks )
I soldered everything in, just doing a short 'does it burn?' test before final installation. So I don't think it's loose wires.
Any ideas what this could be?
