Idler Arm measurement
voodoovette
Crystal Lake Illinois
Hello,
If anyone has an old idler arm sitting around, I am looking for a measurement of the amount of offset there is made into the frame mounting portion of the idler arm assembly. To attempt to clarify, if you took the idler arm mounting flange with the two bolt holes for the frame and placed it on a flat surface, then measure from the center line of the pivot point to the surface. I hope that I am clear enough in my attempted explanation. Let me know if further decryption is needed. I do not have my original arm and I need some measurements for my front suspension, thank you.:)
I just removed all that steering 'stuff' when I installed the rack, if I don't forget I'll dig thru my boxes and see if I can find the idler arm tonight....
