Thanks man, I think I have spotted that page before....I spend about 3 hours last night just looking for some info on the net, found nearly nothing...
I did find some rebuild kits....but this unit was fresh black paint and my comment about missing parts is INCORRECT....in fact, the way 4 different parts houses showed it all this morning, is that I have a correct HB unit by the external pix.....I would swear the steering had good pressure/response yesterday, but maybe I goofed...at any rate jacking up the van/motor home with wheels off the ground, and circulating the steering did nothing....
but now the steering is heavy with NO power assist.....when I loosened the main pressure line to the HB unit....I expected to see fluid piss out so violently it would empty the sump in a second...such was not the case...it did come out, but very slowly.....trick IS, the damn thing was pumping fine just 2 days ago before the HB install....so that tells me some shit in the lines, but where?? what is so restricted?? is there a filter in the p/steering pumps??
there was two basic different types of HB systems I have seen listed, the first one looks like on my vette....listed at one place as for 4 wheel disc cars...interesting....the other looks like what is on this van chassis, and listed for disc/drum applications....I never knew there was any difference ASSuming the issue would be settled by the m/cyl or prop valves, or brake size.....booster?? umphgh....
so the unit I got SEEMS to be the one I need in there.....guess I lucked out on the vette, plugged it in and ran like a top right off the bat...been fine since...
so now to find the pump problem....i'ts NOT a slipping belt, with the dawg house off, I can see the pump running, and it's not slipping, belt/pump is quiet to boot....
I beginning to feel like WADE with his weird engine problems....
:bonkers:
:crutches:
