Yellow73SB
- Joined
- Mar 24, 2008
- Messages
- 1,201
What is the bore of it? Also the stroke
No idea, pull it apart and measure the piston![]()
Its welded together. You can't get at it unless you carefully cut it at the weld with a cutting disk.
I have my original one sitting around i could do a post mortem on. I can at least measure the stroke for now.
Damn, all these years and I never took a close look at that. I have one with a slight leak and saw some rebuilt units for sale on ebay. I thought I would just rebuild it myself. Wrong! Homie don't do welding.....:clobbered:
I know it's welded, that's why I said pull it apart. .
Tomorrow i'll push the piston all the way in and then out and take the mesurements.I don't think anyone here has cut theirs up just to take a peek inside. You can measure the stroke without opening the thing up. .
That won't work if there is any leakage at all past the internal piston or shaft seal. It ain't gonna pull a vacuum.You could also push it all the way in, then suck up fluid by pulling the piston out and then using a measuring cup or cylinder to find out how much fluid you have in it. With the stroke known it's easy to figure out how large the piston is..
The shaft appears to be a polished high carbon steel if not stainless. Mine is not pitted. If any would be mine would. You can rebuild the shaft seal forever and prevent leaks. Its just that the internal piston may have a lot of blow by after many years of wear and corrosion.As for the leaks, if the rod is pitted you can replace the seals but it will leak again in no time.
Thanks for the English lesson![]()
I've seen shafts that were nicked or pitted, possibly from road debris but still, it would damage the seal and it would leak again in no time.
