how much heat ?
78frank
New member
What heat range heat gun do I need to soften adhesive at fenders and firewall/cowl to remove front clip on my 78? 700 to 800 degrees? less ? more? Thanks!!
Can you set the heat on those guns? if so, get the highest capacity one you can get, you will not run out of oomph then if needed, you won't need that kind of heat for the adhesive though
This guy kind of rambles on, but he does show how to seperate panels:
[ame]http://www.youtube.com/watch?v=0E6YC5Iys_I[/ame]
