Yellow73SB
- Joined
- Mar 24, 2008
- Messages
- 1,201
a spare what??not using one. You're a braver man than I. LOL
The C4 toe control setup should still fit with the spare tire tub, there's plenty fo clearance there.
Just get a little spare tire like a C4 has
The temporary spare has to be the same diameter as the four tires on the car. This may(?) be a problem, along with storing the full size (flat) tire that just came off the car, unless the flat tire can be "squished" in there.
A less desirable, but perhaps only option, is to put a smaller diameter spare in there, and then swap a front tire onto the flat back tire corner (to keep from abusing the posi plates on the drive home) and putting the small spare on the front. Once I get the bodywork on the other frame I'll see what the usable space looks like.
Mike
If you decide to go with the small C4 type spare, let me know. I have removed mine and not putting it back in plus I have a second one that I ended up with somehow. If you need it let me know and I will send it your way.
Phil
