bobs77vet
well I had the same problem as everyone else with the HF bead roller way too much deflection of the arms which I measured at 7/16 of an inch when flanging 18 gauge steel. so i beefed mine up using scraps i had lying around the garage. the question i have before i finish all the welds is do i want any deflection in the two arms? currently i have less then 1/16 of an inch in deflection when i tried flanging the 18 gauge steel after the mods. i can easily add some more webbing at the end where the crank is between the angle iron but before i make this too rigid is any deflection useful? thks bob
