hazard lights??
BangkokDean
Bangkok
How do you turn on the hazard lights on my 81? I see the switch on the steering column but how does it work? I tried pushing it in but it does not push in?:sos:
Dean, not surprising, that part of the TS switch assy is not too stable, you can try fiddling with the mounting screws a tad and the button assy breaks off sometimes inside on the little slide...
unless you have to pass some inspection, I would just ignore it....
:clobbered::amazed:
On mine, (81) you pull it out to turn it on.
c-ya
ToddG
Can't be, you push it in, just the inner part not the collar. You pull the collar to disengage the hazards.
Are you pushing the center in ? If I remember right the center pushes in and to turn it off you pull on the outer sleeve.
