JeffP1167
This is on my 97 3.8 camaro. The fuel lines come up through the wheel wells in the engine compartment and then pass in front of the coils and connect to the fuel rails with a quik disconnect fitting. These appear to be some sort of nylon/plastic line, at any rate the feed line has a pin hole and is spraying a stream of fuel .... Can a brass compression fitting be used on these lines and anyone know how to disconnect the fuel line from the fuel rail as in what tool is used?
