Need some ideas.
I checked the runout on the front hubs before I fitted the new rotors and found they had about .014 runout on each side. (on new wheel bearings) Removed the hubs and took them to be machined. The guy doing the work removes the bearing case and centres the hub on the machined section of the hub were the bearing sits. When he checked them he said that they are running true. How can I have .014 on the car and none on the lathe.
Any ideas on what the problem could be.
Doug
Doug
